- Joined
- Jan 5, 2019
- Messages
- 81
- Points
- 76
So I have a recently acquired Punto Evo Sporting 1.4 Multi-Air Turbo and am gradually working through a few minor issues.
One thing I have noticed is an annoying rattle that is apparent when lifting off the accelerator. At first I thought this was something like a loose exhaust heat shield but after a bit of a look tonight I think it is coming from the wastegate control rod. I have not removed the heatshield yet but if I grab the rod that comes out of the vacuum valve and move it I can clearly feel a bit of a rattle. A quick Google and You Tube session suggests there could be play in the rod connection to the wastegate. Either shiming the connection point or adjusting the rod to 'pre-load' the gate look like possible solutions.
Before I dive in has anyone had a similar rattle or opinions on what is the preferred solution. Can a gate wear over time thus requiring a pre-load adjustment? Will varying the pre-load have any adverse effect? I have not definitively determined whether the rattle is coming from the rod linkage, or inside the vacuum valve itself.
Any suggestions welcome, thank you.
