Panda Panda 100HP project (cooperman style!)
Right thought I would start a thread as there are a few mods happening to my panda and wanted somewhere to have them all in one place! I have owned my 100HP since 2010 and love it! She gets serviced at fiat evry year and had belts and water pump replaced last year. I wanted to start modding her but not go OTT as been there and done it before! Hopefully you guys like it!
So this is what I have done:
Day one cleaned!
BMC Panel filter replaced and clear indicator bulbs front and back fitted:
Before
After
Gear leaver blue detailing done with touch up pen:
Ultersport rear 80mm back box fitted, with multi hole exhuast rubber to space it away from the bumper:
Before
After
Home made induction mod give great induction noise over 3000rpm!:D here is the link to how I made it https://www.fiatforum.com/panda/319449-100hp-induction-mod-under-30-a.html:
Before
After
New tax disc holder fitted:
Before
After
Pressed metal plates (Yes I know the legal issues with these before everyone starts kicking off!:devil:) but wanted to have a clean look!
Front
Really happy with the way the car is coming on! The rear end is looking nice and fat, will be looking at getting a silver rear fog light bulb to balance up the lights and looking at spacers the same as Demi has to fill the arches a bit more. All 4 tyres will be getting replaced also for Toyo T1R's as got some cheap front tyres put at the mo and had enough of them!! Lesson learnt!
So I have done it, after days of searching I finally found a pair of original roof rails at a breakers yard in Thorrock Essex the guy only wanted £40 and they came with the fitting bolts also!!! :eek:
Fitting was so easy just remove the plasic screws and bolt these in, below are the results! She is looking like one sweet lil panda! :D (just needs a clean!)
Fitting bolts
Had a bit of a busy day today with the pandavan, repainted the battery securing bracket as it was looking a bit worse for wear.
Before
After
Also gave her a real deep clean and polish, after reading a few reviews I bought some of Halfords own car polish and its one of the best I have tried and I really recommend it! (y)
Also playing around with a chalk board fuel flap with pictures soon!
A interesting week mainly because not all my mods work! Tried fitting a retro AA badge to the bottom front grill just didn't look right, still removed the front fogs so can do the yellow tint film correct this time.
Also not liking my black chalk board fuel flap, bought a spare from a breakers to try it out on but just looks stupid! Stating to have second thoughts on the retro roof rack now think it will make the call look to tail, still might remove the rear wiper tomorrow to get that smooth look. (y)
Doh! What made the chalk board not work?
I think the roof rack would work but just need it to tie in with other bits
It was just the matt black panel looked abit random!! Still done the rear wiper removing mod today and wow looks so smooth and decluttered at the rear now thanks to ittaifasttipo and Harey for the idea :D
Really easy mod to do just pop out the plastic clips, undo the allen bolt that holds the boot pull on and the cover comes off.
Its then a matter of just undoing the 3 allen bolts that hold the wiper motor on and the 10mm bolt that holds the wiper arm on.
I used a section of carbon wrap I had left over dont think it came out to bad. (y)
Looks 100 x better. Still not sure about the roof bars (IMO of course)
Yeah, Coops. Wiper removal is supa! Not so keen on the roof rack thingy, like the others. I think it will make already tall Panda even taller. I doubt u want that. Euro look, yes! Tall and awkward, no so much. Its like a weave basket at the front of an old bicycle, cool. Same basket on a modern road bike would just look out of place. :D
Keep trying thou (y)
Like how u r going for a totally different look than me.
Yeh the roof rails are interesting as some times I think they work and sometimes I think what the hell!!
I'm off to Cornwall in 2 weeks time will leave them on for that and see if my mind changes apart from that she is coming together lovely!! :D
Interesting morning, went out to do a few things and when I came home to put the pandavan back in her garage sounded like the left front wheel was about to fall off!! (Straight away i thought sods law as about to drive down to Newquay on Saturday!!) Rolled the car back and forth and something was grinding good, before I called fiat thought i'd take a look so jacked the front up and after abit of searching found that a stone had got caught between the inner dust cover and the disc!! A bit of wiggling and the stone fell out problem fixed :D
Anyway done a bit of a interesting mod to the power steering bottle it now gives the car wings!! :devil:
Before:
After:
Close up:
Close up:
Nice. I once slid one onto the tailpipe of the Seicento as exhaust trim. It seems a cheap mod.....
I think with scissors and careful use of Araldite you could get some decent RedBull badges to stick on your car and cause forum controversy.
i saw a great set of front headlights with mat black inners with orb and led fittings £199 very cool
i want bbs motorsports on mine 12" back 9" front my bro done his golf like this with rolled 40mm tyres looks sick
