Hi - have owned a 56 plate Multijet for around 3 months now - great car *BUT* have suddenly fallen victim to flooding into the driver's footwell.
It's pretty bad - when one stands on the carpet - a small puddle appears...and can see that the insulation layer under the main carpet is fully saturated.
Only in the driver's footwell -everywhere else is fine.
Have searched the web and this forum - and doesn't appear to be a common issue...
So far, have:
* Removed driver's door card - membrane is fine
* Checked driver's door seals - appear fine, with no drain holes blocked, etc.
* Checked seals around windscreen - all appear tight and continuous.
* Have removed and checked the windscreen scuttle - all appear ok - drain holes are also clear.
* Visually checked under body - no obvious seals missing or holes.
* Nothing appears to be amiss with the front o/s wheel arch liner either...
(Vehicle has no sunroof.)
Am now running out of ideas!
The water ingress is clear and doesn't taste of anything (so also ruling out the coolant system - levels remain static too...)
Anything else? Have Aircon - could it possibly be the condensed output? Anyone ever seen this??
VERY Puzzled!!!
Any advice appreciated.
Hilge
So far, have:
VERY Puzzled!!!
Hilge
