@varesecrazy wrote a nice guideIs there a screw or bolt midway on the pipes, inside car?
I looked on the bulkhead but didn't see anything other than the factory clips connecting the rubber hoses to the plastic heater pipes
Heater Matrix change - Lower Dash removal Info.
:idea: Mystery coolant loss = DAMP Carpets :( chances are you've got a leaky heater Matrix assembly :thumbd: I had these issues, here is a brief run-through of the job.., Glove-box ; remove the 4 small TORX screws from the upper and...
Is far as I remember just this
Should remember as I had mine apart a few times
Tried add grease to the o rings
Tried filing a bit of the matting surfaces
I got pretty close but as it cooled it would suck in a bit of air
In the end I just RTV the two parts together, that lasted while I had the car
