General Seicento heater hose
purf
Established member
UK
Hi everyone
I'm having trouble finding one of these bottom heater hoses, as the 'plastic 90 degree elbow reducer' has snapped.
Its the one that links the temp sensor housing to the heater and also the expansion tank.
Does anyone have one they can spare? I've asked all ebay breakers...
Jeremy
Should be able to find a generic replacement elbow, just measure the diameter needed.
Available easily on eBay search 5/8 16mm elbow.
Thanks - you are right there is a Polyamide one which says it suitabl for vehicle coolant systems. I've not had great experiences with plastic joiners in coolant systems though.
I might be able to tap in an 8mm for the header tank or would have to add a second reducer tee. Hopefully oem hose will turn up on ebay via breakers. Would be nice to have fewer joints.
