Starting to get confused about 'recommended' tyre pressures for my van
Last week had new tyres fitted to my motorhome. Now I have always run the old Michelin tyres
at 55PSI front, and 66PSI rear. Even tyre wear, reasonable (for weight) handling, and did not get too hot on long motorway drives.
Have now changed to Continental Vanco Camper tyres. Garage recommended 65PSI front, 75PSI rear. This to me seemed a little high but ran it for a few days at these pressures but noticed more 'squirrely' on cornering and definately harder ride.
Looking on the sidewall of the new tyres near the tyre size is '69PSI'. Is this Maximum, or Minimum pressure !!!.
Have sent an Email to Continental but no reply yet.
A quick look around some websites (caravan club, Motorhomefacts and others) showed yet more different tyre pressures so getting more confused.
So after a bit more earching found this website for Continental tyres, old, but probably still relevent: https://blobs.continental-tires.com...3fdecf55055ed13a723d5eff564/databook-data.pdf
After some confusion it looks like my tyre pressures for 'known' axle weight should be somewhere between 47-54PSI front, and 50-65PSI rear.
To me, both lower pressures seem too low, but the higher pressures are very close to what I used to run.
So has anyone got a clue what the correct pressures are for the below:
Tyres are Continental Vanco Camper 215/70X15 CP 109R 8 ply
Van front axle weight 1560Kg (These weights measured on local weighbridge)
Van rear axle weight 1720KG
Martin, GM6VXB
Martin, GM6VXB
