- Joined
- Sep 14, 2009
- Messages
- 19,492
- Points
- 3,295
Oh well that special puller idea is a no hoper. Good luck with the repair.
Ironic thing is - went to the mechanic today - he's said yes input bearing shaft
LUCKILY! he had a bloke in 2007 who had a punto who had same problem - but the car never made it as it was wrote off
So sat there ready and waiting is a 1.2 Bearing and Seal
Okay i cant do the work - BUT Atleast the correct parts are already there
Ziggy
The bearings are available as sealed for life types with integral soft seals. Leave one seal in place and pull the seal from the side which will face into the gearbox. Also use the correct seal as back-up. Belt & braces r us.
I strongly suspect parking Puntos on UK roads (with LH camber) leave the gear oil low at the clutch end so its dry when the engine starts. Some side streets with a steep camber or low gutter would be worst of all. Cars parked on the opposite camber or on level drives would be less at risk.
NoCan this be done without taking the hole gearbox out?
Hi can you tell me the exact Loctite sealant as dont want to use wrong one Many Thanks.
The Loctite 5910 Premium Silicone Black Gasket Maker/Sealer 80ml forms a flexible silicon seal and is suitable for use on valve covers, oil pans, intake manifold end seals, timing covers, transmission pans.
