Technical Injector code confusion
priorphilip
Southern
Hi all,
-> Ducato 2017, 177PS, F1AGL411A
Due to injector replacements, I tried to key-in new injector codes. AlfaOBD only allows to enter 7 alfanumeric digits while the code is 8-digit. MES notes to key-in 9 digits but also just allows 7 digits.
Has anyone a clue what to do to enter new injector codes?
What format are you old injector codes in?
Post photo of old injector showing numbers?
Just checked. Current codes look different and are 7 digits
Injector code Cyl. 1: BSAEF1D
Injector code Cyl. 2: CLBLD1E
Injector code Cyl. 3: BSBEF1C
Injector code Cyl. 4: CAASHAD
Anything I can do to program new injectors
I think you have bought incorrect injectors
Do not attempt to use them
There is a risk of damaging either the ecu or the injectors
It is impossible to interchange solenoid type injector and piezo type injector,serious damage will be caused.
I'm not saying that is your situation just be aware of the above
Understand. These injectors came with replacement engine.
Engine has correct motor code F1AGL411A and injectors are originally mounted as far as I can say.
BTW: Im driving this motor 2yr now, knowing of incorrect injector codes with no issues.
Someone else has previously had the same issue and the last figure on all injectors was F. They used the first 7 figures leaving off the F and had no problems.
Using Code without last digit (F) did the trick. Not with AlfaODB, it still complains. But MES is programming the code and I see them in Status report.
I know im late to party still sufferering from black death .
you have correct injector and all injector seem to have the suffix F.
this injector is now obsolete and replaced by 0445 110 520 though took a while to sort out. fisrt off my order was refused as being wrong then reorder and changed to new . heres my old one 2017 2.3 130.
