pan127
- Joined
- Oct 9, 2012
- Messages
- 37
- Points
- 97
So at about 70k miles my 2015 Twin Air S started to produce an intermittent judder. Generally this would occur under load in high gears, most noticeably between 3-4000 rpm. Gradually it has got worse, to the point the dash appeared to shake a little, so I have so far tried the following in that order:
* Injection cleaner
*Different fuel
* Changed plugs
* Changed coils
All no effect , but otherwise it runs perfectly with good mpg and performance, perfect results on MOT gas tester. It's been a great car.
* Next changed offside engine mount ( a real pita) which turned out not to be broken, but sloppy compared to the new one. Result..Hmmmm.. some change - judder a little less extreme at max load... but while less, is now felt more widely through rev range and more noticeable through steering wheel.
Before next step I change the nearside engine mount as well ( even though that one shows no obvious signs of wear) has anyone else come across this issue and found a solution?
* Injection cleaner
*Different fuel
* Changed plugs
* Changed coils
