So, I have fully rebuilt the engine and surprise surprise it started first time before putting it back in the car. I only ran it once or twice for a few minutes but it seemed fine. It idled ok.
Now back in the car it will start but after a while - say a few minutes - it will stutter and stop.
Then it won’t start until it has cooled down.
I have cleaned the carb and fitted a full overhaul kit from Ricambio.
After first running it there was some fuel weeping from the top of the carb - replaced the fibre washer with a rubber washer and that has now stopped.
The float is good ( it’s not got a leak) and the needle valve it operates on seems ok - it operates smoothly. That said I can’t figure out how such a tiny device actually works!
The base of both the carb and the ‘plastic’ base on which it sits were both carefully smoothed flat using a flat surface and piece of abrasive paper.
Fuel pump is new.
Plug number 1 is black - haven’t yet looked at number 2.
It’s the fact that it will start and eventually idle when warm but then stutter and stop that I can’t figure out. Plus of course the plug is covered in black soot.
In total, as a newly rebuilt engine, I would say it hasn’t run for more than 15 minutes in total.
Can’t say I understand the carburettor (!)
It has been rebuilt twice now and I was most careful blow out all of its components with a compressed air line before and during reassembly.
It seems to me that it is a fuel supply issue when it finally stalls but at the same time it is running rich.
I would greatly appreciate any thoughts from the gathered wisdom of this forum. Before I give up and buy a new carb!!
It’s a standard 500cc engine in a ‘72 500L.
Many thanks in anticipation
Peter
Fuel pump is new.
Peter
