Would anyone know how The door stay works ? My door just swings open even though the spring stay is in there. I loosened off the single screw in the door plus removed the stay by squeezing it together looking at the stay it has an indent at the bottom, but it doesn't seem to locate into anything inside the door there seems to be a pair of white plastic thick washers that appear to close together when you tighten the screw in, but the spring seems to be too long as when the door is fully open it won't locate into the indent on the spring.
Are there different door stays for a 500 D Or L? Both doors are the same, neither door will stay open.
