Technical Dammit - changing spark plugs and the terminal on one is broken and stuck in lead!
Bedford
Don't know if that's gonna be salvaged in time for my daughter to get home tonight!
Do you have thin nose pliers?
If yes insert them then pull the handles apart to expand the contact of the ht lead.
Pull out broken part of plug.
Arrgh, you wont believe it, as it was a crappy view I assumed that I could see the broken tip and was getting nowhere using my thin nose pliers so simply thought "in for a penny" and split the rubber skirt as in the picture. Guess what? The tip of the spark plugs not there, I should have just tried it on a spark plug to see! Ah well, I'll buy a new set now as don't think they are available singly and the slice i made is likely to allow moisture in.
