Styling Cool Panda, 16 Inch Low.
The Centre
Looks nice! I think though at removing the front badge whilst leaving the obvious round mounting point and bonnet recess makes it look weird like the badge was stolen.
I wonder what it drives like :)
That's better, steering wheel is now on the correct side.
I had the same wheels 7x16" ET31 (minus the wheel covers) on mine 169, only not that low. (40mm lower @ front and 30mm lower @ the rear, with Koni Sport shocks)
Never had any kind of rubbing, no matter what road surface or load in the car.
I suspect coilers on this one.
Tried fitting 16's on mine, but the rims (even without tyres) touch the gas filler pipe. Can have spacers made but they are quite costly. When you add it all up (rims, tyres, spacers) it'll get expensive, but that does look nice!
If they touch on the inside, the offset (ET for German EinpressTiefe) is too high. Remember ET always has a relation to the overall width. It's not an absolute figure.
gr J
Offset is same as standard, but because they are wider than the standard rims, they touch. Thx though.
