Technical Blower motor resistor location. please help?!
Amybeth98
Hull
Hi everyone
I have a 2007 fiat 500 lounge (1.4) . The resistor has gone in my car. But I can’t see where the heck it is!! I’ve removed the glove compartment in the passenger side as I’ve replaced the blower motor but that wasn’t the issue . Nor were the fuses. But I can’t find the resistor. Any instructions and or pictures would be SO helpful. Ive attached picture for what I’m looking at in the passenger side . Or is the resistor in the drivers side. The hole is where the blower motor goes. I’ve taken it out for now as I look for the resistor but not sure where it is
Hi i think its located on the upper steering column up under the facia! i believe you have to disconnect the column and raise it up to get at it! i am guessing that access will be quite difficult!! might be worth seeing if there is a YOU TUBE VIDEO or the like to steer you right!
