Technical 500 c 2016 uk model
Latchg
London
Hi all, my wife’s car has two problems. Fiat 500c 2016..
1) it says the boot is open all the time when it’s is physically closed.. the boot release works where the number plate light is, so believe the wiring loom is ok.. does the lock mechanism have a sensor within it?
2) her telephone connects to the car and she can hear people, but they cannot hear her. It’s not her phone as have tried another one, and I checked the voice commands using the steering wheel button and the car rewinds.. any ideas please?
I have a 2019 Abarth 595 with the exact same problem
Car has just been serviced (not dealer) and was told by them that it was the boot lock mechanism and the unit needs replacing
Haven't done that yet as it doesn't bother me too much, also the dash warning light is not an MOT failure, but will have to at some point
Interested to see any other comments though I suspect they are correct!!
The post-2013 cabrio isn't prone to the same failures as the hatch but it could still be a wiring issue. I had a broken wire, though mine is pre-2013 with the shorter cable. Is the boot latching properly? Does the boot light go out when the boot's closed? Can you open the roof fully, i.e. stacked over the boot? If the boot's closed but not latched the roof will not go past the 'spoiler' position.
Hi there.
The boot closes properly and the light as best I can see goes off.
The roof does not full open because of the boot open error.
Occasionally I noticed my wife had some boot closure problems , ie bag caught in mechanism, so would try banging the boot lid closed, hitting the already closed latch. If there is a sensor in the locking mechanism then it’s highly probable that it got damaged that way. Does that make sense ?
Seems very similar to my wife’s car.. I removed the locking mechanism and have a part number, might just buy one as under £30.
Will probably get this and try fitting it myself
I'm presuming its the same unit for all the Fiat/Abarth 500's although the part numbers vary slightly
Can anyone confirm this???
Car is only 4 years old with 20k miles, so the tailgate opened infrequently.
Depends on how those 20k miles were accumulated. If it's been used for a lot of short journeys carrying stuff in the boot, it might have been opened more times than you might think.
And opening it a few times in winter when the temperature is below freezing could result in more damage than opening it many times in summer, when it's warmer and the plastic insulation is more flexible.
Surely it wouldn't be the wiring this soon!
Mine failed at this sort of age.
All this doesn't necessarily mean it is the wiring loom failure fault, but I certainly wouldn't rule it out without inspecting it properly.
It's also possible that the microswitch inside the handle may have become stuck/corroded/gummed up; we've seen a few of these too. One quick cheap thing to try is to spray an electrical contact cleaner into the mechanism. Don't use WD40 for this; whilst it might work initially, it'll leave a sticky residue which will attract new dirt, and the solvent can damage some plastics, including the wiring insulation.
I found with ours that the switch is fine even at 14 years old, the problem is the steel pin the handle pivots on rusts and its travel gets less and less as the return spring is small eventually it wont move enough or stuck in "open boot position" dismantling the whole handle/silver part and just cleaning worked a treat and the handle moves far more than ever
Thanks everyone for the reply, given replacing locking unit is the easiest and relatively low cost. I might just try that first
My 500C boot is opened (and shut obviously) at least twice almost every trip and I've had no issues of this sort. Having said that, I've noticed it definitly needs to be slammed a bit harder these days or it doesn't always latch and I get the 'boot open' message (which I usually miss) or I come to open it again only to find it unlatched. It's not obvious as it sits flush with the opening.
Check the bump stops? Or its possible the latching loop has moved very slightly, just enough to require more of a slam?
Thanks John; I'll fiddle with the stops but I'm reluctant to start messing with the latch adjustment in case I make it worse. I've always tried to shut the boot, and of course the bonnet and doors, with a minimum of force, dropping the boot lid from no more than a quarter open, and until recently that's been enough.
Hi all.. the 500c boot open light problem was in the end the wiring loom, fractured cables where it comes out of the main chassis, known defect.
