Tuning 199A6000 and 169A3000
FiatStarJet
Suceava
hello, I don't understand why the 199a6000 model has less power than the 169a3000.
What modifications could I take from the 169a3000 to slightly increase the power to the 199a6000.
And the throttle is plastic, I could use the throttle from the panda 100hp or I could use the throttle from the model Fiat Punto evo 1.4 multiair 77kw.
199a6000 is gasoline engine 1.4 with 70kw
199a3000 is diesel engine 1.3 with 66kw.
So.. what makes you think the oposite about power than the specs say? And which one is the one you want to improve?
The distribution of power trough rpms is always a bit different between motors, especially comparing diesel and gasoline engines, and even more so if one is turbo/supercharged and the other isnt..
motorul meu este 199A6000 si am 95 hp 70kw.
the car's cylinder head was ported intake and exhoust
the throttle valve is made of plastic and has a diameter of 45-50 mm.
and I was thinking of taking from fiat panda 100hp or evo 1.4 multi air 77kw
