I discovered the filter whilst accessing the wiper motor..
it was filthy..so tapped out worst of the ditritis, and sourced a replacement
thanks to MODERN Bravo owner gadge for supplying one at a good price
Lift the bonnet, use the prop in it's secured position.
walk along the LEFT wing until the Black scuttle drain is in front of you,
the access panel is secured with 2 x self-tapper screws,
and then has 3 x location slots cast into the plastic
remove the 2 x screws
( the panel is then "free")
get a flat screwdriver under the rubber screen to bonnet trim - work/slide it along so that the TOP of the access panel is exposed
tilt the top of the panel FORWARD - away from the screen,
then LIFT the panel out of the 3 x retaining slots
