500 OBD2 Diagnostic port- location
A simple GUIDE to accessing your 500's OBD Port
This is a 2 minute job.. Requiring no tools
(y)
Pictures are of a UK Right Hand Drive 500
This is the same 312 FIAT platform as the 2013 panda.. port is in the same location
Access:
Slide back drivers seat
Hold the bottom edge of the panel
(Panel with the small tray located between steering wheel and door)
Apply a firm Pulling pressure to the lower edge of the panel
It should unclip easily ( 2 small clips at bottom and 2x tabs at the top)
The Yellow block is the OBD Port :)
It has tapered edges ( base of a pyramid..)
So the cable's plug has to be the correct way around to fit
Once you are finished with the port
(Disconnect any cables)
Offer the panel back to the Dashboard
The 2 x tabs slide under the dashboard
Then the 2x clips will latch into the 2x slots
JOB DONE (y)
Any tips, or observations
LHD changes..etc
Please post as replies below :)
  • Like
Reactions: GettinBetter
About author
V
have owned 30 + FIATS over the last 30 years,
Italian vehicles, green energy
Guide information
Author
varesecrazy
Article read time
1 min read
Views
6,799
Last update
More in FIAT Cars
More from varesecrazy
