Final bolts
You will find that its fairly loose at this point, but there are 2 more to take out - these can be found behind the pass airbag switch [which just pops out] and there is a small Philips screw behind but BE VERY CAREFUL as the wire on the end of the switch is very thin; you will see when you take that panel of.
Well after those 2 last screws behind the airbag switch, it should pull out steady but once again go steady when you remove it as there is the glove box light wire and more inportant the Pass airbag module wire (this is yellow). I placed the glove box ontop of my tool box just so that it's not hanging by the wires.
