You could try for a Punto 1.1 6 speed as the basis for your box. You would need a quaife ATB but you'd need to engineer a solution for the crown wheel.
Alternatively, subject to costs, you could pop a Sadev 5 spd sequential in. Would need engineered shafts.
There are so many ways to skin this particular cat but you seem to be intent on majoring on the engine.
I prefer to engineer backwards from the wheels up (bear in mind that tarmac rallies confer more wear than gravel).
Sort out a lightweight, but strong wheel, maybe Compomotive. Stick with 13s.
Brakes, Uno turbo fronts are vented and will fit under 13s. You know about the rears.
Shafts, look at using bigger pots, I have smashed a few std CVs. Either that or budget to change at mid event service.
If you set a budget do realise that its very easy to exceed that by 100% without really trying.
Ah I see, so does the 500 gearbox not require the engineering to the crown wheel but still requires the aftermarket differential? I had a look at Sadev and Quaife gearboxes, quite expensive but sequential straight cuts do sound good so it's something to consider
I've never done anything like this so that's why I ended up starting with the engine. I decided to start off with that because it made sense since I was looking at the cc boundaries in the championships and I was allowed up to 1400cc in my chosen one.
Thanks to all of your help though, I know a lot more now so I'm looking into all of these other options that I didn't know about before.
I'll be sure to look into some different wheels but definitely 13s. I think the Panda mk3 diesel disc brakes will be easy enough to get for the fronts so that's a safe bet.
I just have to do the build rather than the actual championship, but I can see why it would rack up so much more money if you keep breaking parts. Replacing cvs and tyres constantly will put up the prices during the races quite significantly! I need to focus on the build though, so I'm going to look into all these other areas. Now I know what engine I want, I'm looking at what needs to go with it i.e. inlet, ECU, wiring, and then all the other bits such as suspension, brakes, wheels and tyres. In no particular order, as I can order everything at the end for the write up with the build
Take a look at the quaife group buy thread on this forum
Why the mk1 inlet if you are using an aftermarket ecu? haltech elite, ecu master black, emerald k6+ etc
check the
eper link in the menu
This was what I was hinting earlier. Its an age thing
. Tyres are everything with a race/rally car. You need to be competitive with engine power but it should always be the last on the list when building a car. Tyres, brakes, suspension, drivetrain ,engine.
The uno brakes won't fit under 13's in a panda due to the upright clearance sadly
I found this thread here for the Quaife differential:
https://www.fiatforum.com/cinquecento-seicento/419542-quaife-lsd-group-buy-interest.html
An aftermarket ECU is easy to find but a custom inlet may not be as easy, unless it really is as simple as getting some throttle bodies like you did?
If that's a good way then I can consider that, if not I could stick to the mk1 electronics as well as the inlet.
I'll be sure to check
eper and get prices when I do the build list and price list!
Perhaps not an age thing as such, but more of an experience thing? Two people that have built several rally cars between them versus a 17 year old who has only changed wheels on a rally car doing a college project
I'm taking all that into consideration now and looking into options for everything else. I think this project is coming along quite nicely now. The brakes and engine are sorted, but I need to get a bit more on suspension, gearbox and I need to decide which inlet/ECU combination to use. But I have options there so it's just a matter of choosing and justifying it. I'll make a little list below so I can consolidate what I've got.
Summary so far:
Car: Fiat Panda Classic
Engine: mk2 Punto 1368cc 16v
Inlet: mk1 Punto 1242 or custom throttle bodies
ECU: mk1 Punto 1242 or aftermarket ECU
Wiring: mk1 Punto 1242 or custom/aftermarket
Gearbox: Fiat 500 6 speed with Quaife differential?
Brakes (front): Fiat Panda mk3 diesel discs and calipers
Brakes (rear): Fiat Panda mk2 front discs and calipers
Suspension: ??? (custom/contact company)
Wheels: 13 inch, possibly compomotive
Tyres: Decided once exact wheels are chosen
So still to be decided: inlet, ECU, wiring, gearbox
Still to be looked at properly: suspension, wheels, tyres
Wheels and tyres should be easy enough but if anyone has more on suspension or the gearbox then that would be helpful. I might contact a company I know to ask about the suspension, and as for the gearbox I do have the option of the 500 gearbox but there is the sequential there as well.
Owen
