- Joined
- Jan 18, 2017
- Messages
- 356
- Points
- 114
A pic from hand book..View attachment 188881
Would it be wrong to use 0W30 in an older '12 TA?
gr J
In almost all cases I would say no.
I changed viscosities, quality, and so on, on lots of cars and bikes without problems at all.
But with the MultiAir and TwinAir units I wouldn't risk anything.
The function of those units depends heavily on oil ( viscosity and quality).
A lot of those units have failed due to wrong oil, so I would stick to the handbook ....!!
I'm a Castrol guy all my life, but since we own an Euro 6 Alfa Giulietta with the 1,4 MultiAir Fiat engine, I use Petronas ( or Selenia...) cause Castol doesn't make a 0W30 C2 synthetic, infortunatley..
Surely if there are no changes to the construction and tolerances in the engine
I'm sure Fiat service use the new spec in older TA engines, I've read it on here before.
It's the other way around, many of them use the old specs oil in the new engines....!!
They have plenty of the old specs oil in store, and not that many new Euro 6 engines around, it's not economical to have the new specs oil in bulk, I'm afraid...
Do we know that? I've yet to see any authoritative statement on that subject, either way.
Where is the best/cheapest place to buy the Selenia Digitek 0W-30 Twin Air engines oil from? I'm hoping you folk have got some advice from your own experiences of buying the oil, either on-line or from a high street retail supplier, as to where the best place is. The Fiat dealer that I bought my TA from very unhelpfully changed franchises a few months after I bought the car so I don't think I can go back there for the oil, and in any case, is a Fiat dealer the cheapest place or will I be paying over the odds? Any advice as to reliable online outlets?
I could top up with another brand of 0W-30 oil I guess but as it is still under warranty I thought I had better stick to the 'proper' stuff.
My TA has used about 2/3rds from the top to bottom marker on the dip stick in 9 months and 5000 miles - is this normal for a brand new TA or should I be asking questions under the basis of the warranty?
I prefer to pay for a rock solid genuine product supplier. Its costly though.
To answer my own question:
Was over at my local Fiatdealer (go-to place for over 20 years now) and the mechanic said to absolutely use 0W30 in the older twinairs as well and change oil very regular. (at least once a year regardless of how much it's used)
gr J
The Euro 5 TA and MA engines are designed for 5W40 C3 oil, but anyway, if your mechanic gives you a written warranty, you can use any oil he advises...!! Otherwise, stick to the handbook.
