something in this picture i wonder?
Maybe...
I spotted a lot of silicone. Looks like ur going to do leather doorcards, where did u get the material and what type is it. Im gonna retrim my doorcards soon in black to match the alfa seats. But I was'nt planning on sticking it on. Im gonna do it Alfa doorcard style with the stitching angled forward. My plan is to mark it out in lines and drill very small holes for the needle and thread to go through. And maybe Ill put a foam backing to pad it out for more luxury! Maybe this mite be worth a try for you MB if the silicone dos'nt work out.
I got it in Navan, a shop called James Joyce on watergate street. €20 for 2 metres. Its leatherette, nearest I could get. I was looking on ebay for just the doorcards but they only sell as a full set. These are temporary untill I get HGT or leather doorcards
Looks more like PVA to me... I'm intrigued to see how this comes out, i'd usually recommend spray adhesive for that kinda thing. Good luck, hope it turns out OK
Cheers! Tis skirting panel adhesive, it stuck my armrest very well so I hope this is the same
Double whammy time, in the bad news sector
First a lesson on how to dismantle a turbo, sort of
Take your time to begin with!
Now, clean it up well and apply plusgas to the bolts on the housings, feeds and brackets
Come back the next day and repeat. Remove the bolts to the wastegate actuator
Withdraw it
Now for the turbine housing youll need to remove the oil feed pipe.
And mark it so it aligns on installation. I just used a marker
Remove 6 bolts. Whip off the inlet turbine housing
Oh dear this one wasn't minded. New turbine needed :bang:
But it gets better. Holding it in a vice, attempted to remove the turbine by holding it on the other side. Spins freely
Turns out the shaft has snapped in the middle!!!!
So it gets the bin once reassembled
Now onto my other misfortune
On monday, driving along, suddenly no power.
I've made a thread about it but I'll run over the parts I've changed below along with the vid of the problem. The thread goes into a bit more detail I may have missed below, its the full story.
Well the video is more appropriate first I guess. This is the running problem: It works only at full boot. Any other position the throttle is in, the car gets starved of fuel. Full boot, it opens. Don't mind the video and sound at the end too much it becomes unsynchronised
Since monday the crank sensor
Elusive throttle body...
Temp sensor/sender...
And airmass meter...
Have been all changed. The maxi fuses were cleaned up
Holder cleaned
And then I decided to use new fuses
With copper grease
And it still runs like crap
If anyone can shed some light on this I will very much appreciate it!!!
