General Tyre size on standard steel rim
PetoChamb
Hi All.
I'm planning on a nut n bolt restoration with new rims CMR. I currently have standard steel rims fitted with 125SR12 CN54. I need to replace the tyres however, I want to fit 135SR/70/12 on the old rims then move them onto the new when I'm ready. Will this work?
TIA
Model
500L classic
Year
1970
Hi All.
TIA
I think that you will have no problem with fitting 135 tyres, but why not use the extra width of the new tyres better and fit them onto Mk 1 "126" wheels which are 4 inch wheels---same wheel bolt pattern---190pcd, but MK1 wheels, NOT the Mk2 wheels which have the later 98pcd wheel-bolt pattern. Do not forget---BOTH of these wheels will require inner-tubes to be fitted as they do NOT have the tyre-rim retaining ridge built into them
Hi. Thanks for your info appreciated. I’m planning on buying new CMR tubeless rims later this year, fitting on the old rims is temporary until then.
Thanks again.
Ade
Hi
Can i ask why you want to change size? is it to lower the car?
The CN54 tyres are currently actually made by Pirelli themselves. they make the correct 125R12 Cinturato CN54 and the 145/70R12 Cinturato CN54 as well, both can be fitted with inner tubes.
https://www.longstonetyres.co.uk/pirelli-collezione/pirelli-cinturato-cn54.html
The big advantage you have with the CN54 is it has a carcass suited to your car, where a modern tyre is built to work with different geometry.
