Being a complete rookie here, but could some please explain tyre size and diameter etc, and offsets? And what ones are best for a mk2 punto. Looking for some alloys for mine, would be very greatful.
Cheers guys
Rich
2 replies at same time, both with same info....
Depends entirely what size alloys you buy.
However the rolling radius, Total diameter, should be kept the same to keep your speedo accurate.
The standard Fiat 15" Alloys come with 185/55 15, this means that the width of the tyre is 185, the Profile percentage is 55 (the lower the thinner the sidewall look Hence "LOW PROFILE") and the 15 regards the inner diameter or Rim size.
The bigger the Rim diameter then the smaller the required profile gets.
i currently have Fiat500 alloys which are wider than standard, and are 16". these require 195/45 16 tyres. These have a width of 195. a profile of 45 which makes them LowProfile and are 16".
I wouldnt recommend getting anything wider than 195, 205 at the most. as any larger would rub on the arches. also 17" are going to be extreme low profile on a punto.
Regarding OFFSET;
This is how much the hub is from the centre of the alloy. Negative offset means the hub is closer to the out of the alloy. Nutral is normal and Positive offset "pushes" the alloy outwards similar to what "Spacers" do.
Hope this helps
So basically, as I have an 1.2 8v, im guessing the suspension set up will be alot different to that of a sporting, so when i get new alloys, ideally i want them to sit without huge gaps between the wheels and arches, without lowering it at all. what sizes etc would you suggest? cheers pal
here is mine with 195/45 r16s
here is russ' with same size
so unless u buy lowering springs they will sit like this
fkautomotive are doing 60/40mm lowering springs for £46
so basically, if i just went for the the standard sporting alloys and tyres, would is sit different to a sporting? looking high and silly, or not? sorry for the stupidity.
cheers guys
okay i will probs just get them, think yours and others ive seen are alot nice tho mate! just in terms of cash, hopefully i can find some ones in alright condition of ebay or a scrappy, unless anyones selling any on here! side skirts are my next project lol, really want abarth ones but cant find them anywhere!
yes, sportings are 20mm lower standard
