Thank you guys for all of your wisdom and advice!! I'm serious! My engine is a 1979 cs2, My timing belt kit gets delivered in 2 days, today I had a short time to remove the front coolant system which I have all new hoses for, as well as the fan assembly, and getting the radiator unbolted, since my spider is an automatic I'm soaking the coolant lines to the radiator in penetrant until tomorrow so that nothing goes wrong loosening them, then with the radiator out I can remove the yellow cover and hopefully have a "oh, so that's how it works" moment....my brain was making me think the belt needs to go under the crank, and how can it with the pulley and lower cover on..I'm hoping no more questions and I will post a pic after the new belt is on, turned 2 full revolutions, then with the tensioner tightened down...P.S. thanks for the advice about the timing tab, I was hoping it re- indexes it self! Also, once the timing tab is removed does the new belt squeeze thru this space to get under the crankshaft?
