SuperHarley
A few months ago, a mechanic said timing was perfect, i.e. 10 degrees BTDC at 850 RPM. Just failed California smog test because it is 27 BTDC and 1100 PRM. At higher RPMs, vacuum advance worked. I could not budge the distributor by hand, so I do not know how the timing could have changed. 1) Can timing at idle change other than by turning the distributor? 2) The clamp nut is underneath the distributor and appears to be 17mm, but the surrounding space is too small to use any of my wrenches. Is there a special tool for this? Thanks.
- Model
- Spider 2000 fuel injected
- Year
- 1982
- Mileage
- 200500
