Nah, all of the wheels on the i3 are forged aluminium so far lighter as a wheel than a conventional wheel and tyre assembly. They have also been designed with aerodynamics in mind.
The damping is still bad on all 500's. I've a journalist friend who drove an abarth and bemoaned the complete lack of suspension.
oh wow thats pretty high I am halfway between max and min on mine.My 500 isn't that low tbh. With better damping it doesn't wobble all over the place and IMHO is less likely to hit anything. It's at maximum ride height so it's lost maybe 20 or 30 mm at most.
Whats the ride quality like with the B14's Maxi? Looks well btw and not silly low.
depends on the road maxi. on the motorway I am very happy with it, on rubbish cobblestone roads its a hassle.It's not soft or comfy as such, BUT when you hit a bump it only takes one oscillation of the spring to sort itself out..... with the old suspension it took far longer to sort itself out and deal with bumps which is uncomfortable imho. It also never hits the bumpstops anymore.
Personally I would say it's more comfortable now, but others may disagree.
Lowering isn't an option for me as I need all the ground clearance I can get. I'm curious if it would help if Fiat were to streamline the underside of the car - mine doesn't even have an undertray. I doubt you could do much else with the aerodynamics without spoiling the appearance - and without that, I doubt Fiat would sell even 20% of the 500's they do.
i'll check the clearance of mine with a tape measure later on. I am halfway between min max on mine. I find mine to be a good compromise, not too low not too high, it is much better damped so only bottoms out on really unstraight roads, and even then with the 1.4's hard plastic skid plate, it really isn't much of an issue.Surprised how low that is on max. We have a 100mm minimum clearance to be street legal, you can't be much above that. Look forward to mine looking like that *someday*.
Just checked our 500TA.i'll check the clearance of mine with a tape measure later on.
Went out into the hills for a good blast on narrow tyres, basically drove like I stole it. UFI handles a lot better on the less grippy tyres, you can get lift off oversteer now and point much more aggressively at apexes. On the 195's all I ever got was understeer, even driven on a closed circuit.
Over a 50 mile run, lots of heavy throttle and shifting at 4-5K, I got 66MPG UK. The tank looks like returning 62MPG with a lot of running about back and forth across the city.
You going to be in the UK anytime? Mine understeers![]()
I don't really get that, to get 66mpg from mine I would need to drive uber carefully, I don't believe the tyres are making the difference between mid to low 40's which is what I would typically get driving similarly ( on 15's) and your 66. That's a big discrepancy.
You do have to be fairly aggressive with your lift off or braking but yes, mild oversteer is possible now (enough that you have to wind off lock), and I may be in the UK this time next year
Bare in mind that on 16's I'd still be getting 50mpg + driven on the same roads in the same manner. Even inclusive of a track day on my fifth tank from new I managed over 47MPG. I don't know how I'd have to drive to get into the low 40's now.
So in your opinion what's causing the big gap?
