General Turbo Engine - cool down period
Ashford, Kent
I am still getting used to my 2019 Cross Plus 1 litre. Reading through the manual it states..
ENGINE COOLING ON TURBO VERSIONS (Page 135)
Before switching the engine off, keep it idling for a few minutes so that the turbocharger can be suitably lubricated.
This procedure is particularly recommended after a demanding drive.
After a full load operation, or anyway after heavy power demands, keep the engine idling for 3 to 5 minutes before switching it off.
This time allows the lubricating oil and the engine coolant to eliminate the excessive heat from combustion chamber, bearings, inner components and turbocharger.
How many drivers do you see doing this? Presumably it applies to all turbo cars. I can understand it after a really long run, but it seems a bit much to expect that after every journey you sit "for a few minutes" before switching the car off. I am assuming that this only really applies after a demanding drive.
Model
Cross PLus
2019
I always let the turbo cool if I have been blasting along, theses days that is not so often. Better practice is slow down for the last 3 to 5 miles and dont work the turbo Then it should be less relevant. If you tow or have a full load and passengers its more vital. Failing to allow the turbo to slow, cool and indeed stop will lead to heavier wear and early turbo seal failures. The oil round the bearings will cook and this is bad and not good all round. Easing off for the last few miles is best practice. Turbos will glow red hot if worked hard which shows what extremes they are subject to.
