Technical Transmission problem
Mahmoud144
Egypt
Hello , friends
I am from Egypt, I have a problem in my transmission , on the morning while car is cold , I have difficulty to get Gear to R , and I must to shift gear to 1 then R ,
Also when car in Postion N can't go directly to R
Colud you help me please to find out the problem and how to be solve
Best regards
Reading the posts here I assume the FIAT dealers don't know / care about the Dualogic...
The Dualogic / Selespeed / Comfortmatic / F1 gearbox is a robotized manual gearbox. It needs regular and precise servicing. If not taken care properly of, it gets problematic. It has been installed across most of the FIAT makes (Alfa Romeo, FIAT, Lancia, Maserati) under different commercial names, but generally the system is the same. And has same problems...
It has 3 fluids. Including the DOT4 fluid, which is highly higroscopic, so it should be replaced every 2 to max 4 years to maintain its properties.
Here's the official FIAT diagnostic on the Dualogic. This one has been published for the AlfaRomeo, but as mentionned earlier, the system is the same, part localisation and minor things might differ. It contains instructions on fitting the new hydraulic unit:
Thanks dear for help i will read , but I know two types of oil , gear oil ,and unit oil, what is the third one ? 🤔
Another thread explaining the fluids. However it says DOT3 on the photo, so that shall be confirmed.
And another one, saying it's DOT4:
Another one:
Another one:
