- Joined
- Apr 26, 2011
- Messages
- 2,102
- Points
- 373
BEFORE you fit them and forget may I suggest you liberally spray the threads with WD40 then use a wire brush to clean them finishing with a coating of grease. Then fit the caps
If you don't do this then you will have next to no chance of removing the top nut (and you will) without heat and a 3ft bar!
Good tip - plan to do this on mine at the weekend.
