Where is good to buy - and do I really need?
( I have googled - get a load of Audi stuff)
The typex method worked fine for me.
I wouidnt trust it or recommend it..
For what reason however?
Because its not worth the risk..
Not only that. Its hard to get timing bang on with out the correct tools..
Yes - the 16v really does need locking tools to time the engine up before belt replacement
you need 2x Cam locking pins
and 2 cylinder height pin things as a bare minimum
Ziggy
I see your point on the top sprocket..
Its best done that way...as you can then tension the belt correctly without the timing shifting..
There is no key way..this iguess scares people...
Never seen one loosen off anyhow...
i agree with all this yet in the guides section there is a guide using tipex and kebab sticks for piston hight tools, kebab sticks are not even precision made can be different lengths and be bowed. please go report the guide and share your concerns before some one does serious damage to their engine.Tightening the sprockets back up - do it to factory spec and you should be perfectly fine!
Ziggy
