Technical Tipo Sedici - where the low beam realy ?!
VertigoT
Hi all !!
It is already several days the headlights dont work for me, the high beams are works perfectly but the low ones died ! I checked the fuses at all - all fine !
Somebody can tell me pls where in the fuse box the correctly relay of the low beams ? :bang:
Thank you !
Hi all !!
Thank you !
what build year..?? Mk1 or 2;)
So after the check, all relays are working.
What can be the problem of low beam ?! :bang:
have you checked the low beam filaments are not broken it can happen
  • Like
Reactions: SFB
Check the wiring behind the actual light cluster... the wires are very thin and they can fail. I changed the connectors and a short section of wire on my Tipo a few years ago.. I used the connector and wires from an Uno which were thicker. No problems since then....
A half hour with a circuit tester would be enough for anyone with even a rough idea of where to look, so find a friend who can, or if all else fails, your local auto electrician.
Make sure to do what rick500 suggested first!
