hi, since iv had my amped 6x9's iv had a problem with one of them, i thought it was a blown speaker to start with so i took it out (stealth shelf) and to my surprise it was? the tweeter dome had split, so i sent he 6x9s back and got some replacements, i installed these and noticed one wasnt reacting at all to bass? so i thought it was more broken speakers, sent them back, got new ones, (warrenty is now out of date), and still i have one of them not working properly, it distorts and doesnt have bass. i didnt think it was the amp because the "broken" speaker was on different sides each time, but i tested the amp anyway, it seems that the 6x9 connected to the left outputs (See Pic) dosent work, i have chenged the fuses but now im stuck. firstly, the amp:
Specifications:
Maximum output power
2 x 1500 Watts @ 2 ohms
2 x 1000 Watts @ 4 ohms
1 x 2000 Watts @ 4 ohms (bridged)
Frequency response
20Hz ~ 30KHz ± 1 dB
Input sensitivity
< 250 mV
Signal/Noise Ratio
99 dB
Speaker impedance
Stereo output: 2 ~ 16 ohms
Bridged output: 4 ~ 16 ohms
6x9's
Specifications (per pair):
Power Handling (Peak)
2,000 watts
Power Continuous (RMS)
350 watts
Frequency Response
50 Hz - 22 kHz
Sensitivity
93 dB
Impedance
4 ohms
Resonant Frequency (Fs)
50 Hz
Total Equivalent Factor (Qts)
0.53
Vol of Acoustic Susp. (Vas)
36 lit
Linear Excursion (Xmax)
6 mm
Displacement Volume (Vd)
0.0035 cuft
Tweeter
1.6" Titanium Dome
Crossover
6 dB / slope
thanks.
Specifications:
Frequency response
20Hz ~ 30KHz ± 1 dB
Input sensitivity
< 250 mV
Signal/Noise Ratio
99 dB
Speaker impedance
6x9's
2,000 watts
350 watts
Frequency Response
50 Hz - 22 kHz
Sensitivity
93 dB
Impedance
4 ohms
50 Hz
0.53
36 lit
6 mm
0.0035 cuft
Tweeter
1.6" Titanium Dome
Crossover
6 dB / slope
thanks.
