The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hello, could someone give me the code for my radio?
BP - Nr. 7 642 375 316
Prod. Nr. Fiat 735 337 934
please post the main BP2375x1234567 number can be found stamped in to the metal casing.
HI can you tell me the code for
Fiat Ducato CD NS
7 643 318 616
815 BP 3318 4 1187835
Cheers Greg
hi all.
need a radio code as just swapped my old fiat tape player for a cd version.
all the numbers that are on the radio are
serial m034871
fiat prt numb 735392558
visteon prt numb vp4fcf-18c838-da.
hope someone can help.
thanks
brian
I live in THAILAND and just own 500
and do not have code-card.
please help me Mr.Davren.
my BP-Nr 7 647 389 316
Fiat Nr 735 452 486 0
thank for advance.
Hi, I didn't realise that i did not ask previous owner of car for car radio code. Could you please be so kind to help me with code?
Prod Nr. Fiat 735 337 934
BP237547048898
Thank you in advance!
Best regards!
i really want to made donation for your website
but i don't have or use any creditcard here.
and if you still want to help me.
my s/n is BP738987114312
thank you in advance.:eek:
Re: blaupunkt radio code
try code 2341 or if you can enter higher than a six code 4727
Thanks for the Code , But I 'm unable to enter the code as the display keeps reading " Radio Blocked/ Wait " . I read somewhere in the forum that you need to keep the Ignition key at ON for 2 hrs then it will show" Enter Code ____" tried that dint work can you suggest wt should be done for this.
Thanks and Regards,
Rajat Khanna
Thanks and Regards,
Rajat Khanna
You need to leave the ignition and radio switched on for up to 2 hour until the display shows " CODE " then "- - - - " then enter the code.
