The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
It's a Magneti Marelli, but from a little research it seems the only way to get the code is by reading the flash memory, sorry 😔
Ah, shucks!
That doesn't even sound like the type of job alfa would do, unless they're able to look up card codes from a database against serial number?
Afternoon, if possible, could I get the code for this Bosch head unit please. Thanks
We have a fiat doblo maxi van through the business that had a flat battery and requiring a code. Cannot find any paperwork for it from the factory (under 2yrs old)
Has android/apple car play unit installed.
Theres one small bit of paper with FGZ3264 on it - is that likely to be it?
Do you know what model the unit is?
it is one of my staff's vans so i don't have access to it each day, this is the image they've sent me. Would i need to strip it down to get a code from the rear of the unit
Hello. I've been searching my blaupunkt radio code but never found a code that worked.
A member from another forum provided me with the code 5424 but did not work.
Blaupunkt
815 BP854382484532
7 648 543 316
I need your help my stereo required a passcode (4 digit code)
Where some garages prefer to not put to much effort into this kind of support and with their words "It might take up to a week to get the code", it took LESS than 10 minutes between my inquiry and receiving it the via the 'shop' of this forum!
Thanks for the support!
  • Love
Reactions: ben
