Technical Strange noise when driving in 1st and 2nd
Elxpunto90
Hi guys I've noticed a sort out rattle Grindy noise coming from gearbox when only in 1st or 2nd when pulling away but other gears are fine car drive ok no probs just annoying noise it's a 1.2 8v 60 only done 50,000 on clock any suggestions
It's quiet when stationery only makes noise when in gear moving
Yes sounds like a louder version of the old fashion hand operated drill you used to have at school putting that way
It did happen to a similar sound was very clear when traveling along side of a wall and it and I figure out that it was low oil in gearbox it took about 1litre .
Sounds like input shaft bearing, the load is reduced as you go up the gears so the noise goes off. You can either live with it or put another box in.
