- Joined
- Apr 23, 2015
- Messages
- 50
- Points
- 97
How do you fix your steering column to reduce the flex.
So those of you with a 126 steering rack on a 500 classic,I’ve noticed there is plenty of flex of the sloping bulkhead.
I’ve ordered a 20mm pillow bearing, and made up a sleeve internal diameter of 15mm (o/d20mm ) to slide over column and be captive in the bearing.
The column will need cutting, and the sleeve will rejoin the shaft , and be clamped with 4 opposed grubscrews.
So then the fixing to the bulkhead : The flex is more apparent nearer the top UJ, than the lower UJ.
What sort of reinforcement have you guys done, the top side would cause interference to the fuel tank. I’m thinking inside the cabin would be most appropriate, say using some 5mm ally plate 300mm square +- ?
