M mrbasstrombone New member Joined Mar 19, 2015 Messages 1 Points 1 Mar 19, 2015 #1 I am trying to locate the speedometer sensor on a 2007 Fiat Grande Punto. Can anyone help please?
maggers Up to no good somewhere.. Joined May 8, 2013 Messages 831 Points 175 Location Cannock, Staffs. Mar 19, 2015 #2 It's either in the top of the gearbox above the diff or more likely the speedo drives off the ABS
E electricautocustom New member Joined Mar 17, 2015 Messages 6 Points 1 Mar 19, 2015 #3 Hello, you do not have a speedometer sensor, the speed is calculated from the ABS sensors, the signal from ABS sensors goes to ABS module > BCM > instrumens. Your ABS works properly?
