Technical Speedometer sensor location
mrbasstrombone
I am trying to locate the speedometer sensor on a 2007 Fiat Grande Punto. Can anyone help please?
It's either in the top of the gearbox above the diff or more likely the speedo drives off the ABS
Hello, you do not have a speedometer sensor, the speed is calculated from the ABS sensors, the signal from ABS sensors goes to ABS module > BCM > instrumens. Your ABS works properly?
