food for thought
- Joined
- Feb 8, 2020
- Messages
- 6
- Points
- 2
Ok thanks' for your time I shall keep persevering
Ok thanks' for your time I shall keep persevering![]()
Thank you Mr. Herts Hillhopper,
My rear window washer pipe had popped off at a joint behind the scuttle, due to being iced up. Fixed no bother thanks to your posts.
That method worked on the Panda 169 shape. Once I knew where to reach, I could do this and hear the gunk drop out. But a few times I accidentally lost grip and they popped off and fell loose in that empty void where the water sits... If you get a feel for it you can do this regularly and it'll do the job. But if you've never done it or have years of gunk, you might need them out fully to scoop it out.I find I can just get a hand on the duckbills and give them a squeeze from under the bonnet to release water and wash away mud. One day I am going to get them out and trim them slightly to open up the outlet slightly. I think they are designed to reduce flow to prevent water getting everywhere including onto the starter, alternator and aircon. Do they work?? I think its debatable.
