- Joined
- Jan 20, 2013
- Messages
- 6,151
- Points
- 1,228
Would you say that this leak looks like it is coming from the cam seal or somewhere else? I think its coming from the one on the side of the ignition coil as there is no oil on the timing belt side. Really need some help as i have no idea what it could be, its my first car and already had so much go wrong with itany help is really appreciated, thanks
on thermostat side it can only be camshaft oil seal or coil pack rubber o ring seal, all easy to do
https://www.fiatforum.com/punto-mk2-2b-guides/340549-1-2-8v-cam-rocker-cover-gasket-change.html
what else is wrong with it, as this oil leak is nothing to rly worry about
