General Recommended DAB aerial replacement
sootymarmaladedip
West Yorkshire
I've just fitted a replacement DAB aerial to my ducato campervan after finding the door mirror aerial had failed and after faffing around various replacements inclusing a stick on the inside aerial which gave middling results I shelled out for an InCarTec external windscreen mounted aerial that is really easy to fit and gives excellent results. Th aerial uses a capacitance method to pass the signal through the glass to the stick receiver part so no drilling is required. It's a quality product and a complete solution right through to the DAB socket on the radio, very pleased with it and well worth the cost
Hi just found your comment re the Incartec Dab External Aerial, I have just bought the same for our Motorhome, our Pioneer has a Phantom Feed so know issue there, just curious where you mounted it on the Windscreen, we have Remis Blinds which is why I went for this as dont want to dismantle them, but we do have an over cab Sleeping compartment.
