General Rear window winder "omega" clip
danielzieba
hi all.
can anyone send me the small omega clip which holds the rear window winder in place?
Daniel
ePer doesn't show it ...
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
Do you still have the remains of the old clip? Can you still bend it back to an approximate shape?
If you fit the clip and handle without the plastic washer you should be able to convince yourself the clip will hold the handle.
I have found the best way to remove these handles is to lever the plastic washer away from the fabric with a large screwdriver (using a spanner on wood to protect the fabric) as if you are going to completely destroy the plastic washer in a rage, get hold of the clip and then heat the plastic washer later with a hot air gun before refitting it.
no, i havnt got the original one. it's been lost for years. i've only just got round to replacing the window mechanism but can't get old of a replacement clip anywhere
