- Joined
- Sep 14, 2009
- Messages
- 19,897
- Points
- 3,411
My brother has had his 2003 Panda rear axle examined and found the left swing arm is bent (affecting toe angle) and right might have an odd camber. So we are looking at fitting a new axle. IM Axles from Nottingham are the original pattern suppliers but others are now cheaper and probably from the same Chinese factory.
The wheel spindle studs (4 each side) are badly rusted. New studs will be required. They are a fine thread. Can anyone confirm if its M10 fine? EPER is no help and I don't want the car off the road for days while the correct bolts arrive.
M10 fine is my best guess as the exposed threads are rusty - wont let me try a nut for fit and I can't get access to use a thread gauge.
Can anyone confirm if the rear spindle studs are M10 fine?
