Bravo Random cloud of white smoke
Bravo CPT
Hi
I just joined.I own a 2010 150hp bravo. Love the car,but recently it started smoking randomly and only a for seconds. Any advise? The turbo has been checked and no fault found.
Hi, this happens any time hot or cold, driving or at idle.
Hi all, it's the PCV valve that's stuffed. This also explains the oil consumption. Thought oil usage was because car has 183 000km on the colcks. Replacing it tomorrow as I'm waiting for the part. It's completely stuffed up. I'm looking forward to having my baby back at full power, non-smoking and not sucking so much oil. I've been ready lots posts and have learned a lot about my baby. Planning some mods next year.
Want to change head lights to one with LED running light, air filter and radio. Already taken the cat, is it worthwhile to remove the center box on the exhaust?
Still deciding about re-mapping? Is it worth it?
Also ordering replacement key casing as mine is falling apart.
By the way I have a 2008 1.4 tjet 150hp sport.
One other thing, there's a vibration under acceleration coming from the front wheels. Any idea what might be causing this. I've been told it might be the cv joints showing wear.
Here is some pictures
Hi guys, the PCV valve was badly blocked and partly cracked. New one fitted now. Thanks to what I read on this forum I was able to find the problem and get it sorted.
Hi Bravo CPT, where did you manage to get your PCV valve? Ive been looking all over but no luck.
