when you say no power, literally doesn't turn on or off?Hi my radio in my 500S has no power and the odometer is flashing any ideas.
That is correct it will not turn on at all.when you say no power, literally doesn't turn on or off?
Is this a recent issue?
Have you checked the fuse?
There will be a controlling fuse somewhere -
.... also have you had any issues with the hatch wiring?
Thank you ill check tomorrowFuse 36 on the bcm control module controls audio and climate control functions!- PITA to get to and check though! you have to strip out glovebox cubby and some of the dash and then theres a metal "security" box around the bcm module as well! fuses are the "mini" blade type small and fiddly to remove even with the right puller!.
3rd one up on left hand side as you look at the module! 10amp.Thank you ill check tomorrow
Think he said hes already checked that in an earlier post John!Also note there's often a fuse on the rear of the radio itself
