500 (New)  Radio problems
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Tmoor21
Ireland
Hi my radio on my 500S has no power going to it and the odometer is flashing.
Has anyone any ideas
Some ideas: the radio is actually a CAN-Bus node and for some reason it's not found in the network. Odometer flashes.
There can be several reasons:
The radio has no power (check fusibles, wiring)
The radio was recently swapped or there is some other reason why the CAN-Bus network suddenly won't find it anymore (you need to do a procedure called proxy alignment)
There a plenty of threads on this forum for this problem
