Technical Quick climate control question
Just my luck! My car's a 10/2012 build so I don't know whether it's likely to fail or not!
If it's a late November 2012 build date it's probably the later spec
Kate November seems to be around the charge the later specs parts presumably they have a yearly maitance shutdown it some of the factors around that time of year
Thanks for the information but my car's October built. Nonetheless there appear to be two small hex screws on the pollen cover.
Obviously I haven't dusted under here for a while - very slack! Is this what it's supposed to look like? I'm assuming the two silver screws are those in question. The lower one has the plastic cut away which I reckon my mechanic did for access when he replaced the filter a couple of years ago. The old filter was in there from new (6 years) and looked almost unused.
Mines different to yours and at present I’ve only one screw in mine looks like I have even less access than yours unless it’s just the pic
Definitely late type
