Styling Punto mk2b, Which white H7 lamp?
sparkymk2b
Italy
Hello guys, I need new lamp with white color for my Punto mk2b, which lamp will you recommend to me?
I look for Osram Cool Blue H7 55W, is it ok? or something else
The mk2 uses a H7 for the Headlight
its a 55w, dont bother using a 65w,
the Hi-beam is a h1
Anything like
Orsam Nightbreaker (PLUS) or Unliminted
halfords Extreme (very expensive tho)
Phillips Night vision
And there is another but cant remember it
Make sure you fit the bulb the correct way around too - upside down - no beam pattern and you blind everybody and wont be able to see either!
ziggy
Hey I buy Osram cool blue H7 and w5w small lamp osram blue, it cost 32€ :)
I thought the main beam is H7 as well....Sure as hell looked like a H7 when I pulled them out by accident instead of the headlights
Osrams are good but for a few pound more you can get the Philips equivalent which last longer then the osram
Osram even mention on that the life span of these bulbs are less then the normal bulbs that you put in, my friend had to replace his twice in a year but he's an idiot so he probably touched the bulb!
But I do use osram bulbs but I wish I brought the Philips for a few quid more
Some of them are; but others are H1. We've even had people reporting H7 in one cluster, and H1 in the other...! That's why you should always check, before replacing...! (y)
I had the Osram night breaker plus bulbs which both blew within a month of each other at about 10 months old, not worth the hassle or expense so I went back to a regular standard bulb.
On the mk2b headlights are H7 main beams are H1 and I've never heard of any variation of this, although mk2 cars are known to have differences in the bulbs used
