Technical Punto EVO Heater console replacement
Danny75
Essex
I have a Punto EVO 1.2 for my son. The heater doesn’t light up an don eof the knobs has fell off.
It is a non air con console, but would a console which has the Air con button still fit and work as normal ( Obviously not the Air Con)
Attached is the one I am looking to buy to replace the current one in the vehicle.
And the current one in the car
Physically it may fit, but the problem might be a different size/shape wiring plugs at the back.
I had that lot and lower consol out on daughters 2010 Punto Evo to change the BCM module, but that was about a year ago.
You could ask the seller, often breakers are quite knowledgeable, alternatively if fairly cheap, I would buy it as it may be possible to swap individual switches to old unit.
Another thing you could remove yours and compare the wiring plug side with photos to the seller.
Thank you
